03 rx-1 turbo
buddy is currently running a simmons cpr kit - stock carbed engine with a head shim with an m24 and want to upgrade for more horespower...thinking of a gt 2860 and would like to know what AR is suggested an any other things that may be required..also hoping it will be close to bolting up..thanks
man you yammy guys...dont worry..i think i found it..most of you guys were probably riding all weekend anyway.
gt 2860 rs
mitsubishi 16t
still cant find the compressor or turbine side AR`s
could really use some numbers
I would use a 2871 with a 0.64 AR on a front mount, less heat and back pressure. The 0.64 housing is preferred for faster spool up on the 2860 as well. Alpine or Powderlites will be able to sell you either turbo. 0.64 and 0.86 a/r are the most commonly used.
DL
thanks guys...looking into all these different turbo, its funny because you
can go right up to a 30 series turbo and still have a 25 series turbine size frame...makes sense for a faster spool up but less heat and backpressure with
a 28 frame one would think.
2860 with .64
hi, i just put a 2860 on my front mount powderlites turbo kit.the sled is a different sled now ,way faster and more responsive.my first turbo was a 2554 then i went to a 2560 with the ported wastegate and ceramic coating.the 2860 would be a good turbo for your sled.i couldnt believe how much of a difference my sled is with the 2860 ,which is also ported and ceramic coated.i thought i was on a different sled and couldnt believe it was my sled.you will like the 2860. this is on an 04 rx1 .hope this helps.
