03 belt adjustment????
B
Banshee AL
I'm a bit rusty on this old 1M Cat, How do I adjust belt deflection on a 03 1M Cat?:rolleyes:
I need the belt to set a bit deeper into the pulley sides on the secondary there is too much of the belt out past the rim edge which makes the belt too tight.
Thanks
Take the three nuts off holding the roller cover on your secondary. pull the moveable sheeve. either remove or install more washers to make your adjustment. Remove one to make it tighter. Add one to loosen it.
Thunder
