G
gtfoxy
I didn't want to hijack the other Heel clicker thread so I am posting my own.
I have a 03 SKS 700 VES, stock 144x1.25 Predator track, It is geared 21/40, SLP Can, button secondary.
I am mostly a on/off trail rider and want a good acting clutch for a variety of conditions. A lot of the trails around me are slow cornered where fast backshifting in the 4-5000RPM range is needed. I want a smooth engagement for on trail of about 4,300-4,500RPM with good linear pull. This set-up needs to also work well for sidehilling and on/off throttle ditch running (30-40 foot hills and revines). I'm shooting for 8,100-8,200RPM on the shiftout.
Elevation is 1,000ft. I would like a deep snow set-up with a lower engagement to help get on top of the snow and not dig down for when I head up to the UP for some off trail cross country riding.
I'm using 55-7's and began with what HC recomended, for weight set-up 3.2g all three possitions. I am running a EPI Red 145-300 primary, SLP 40-52/34 Helix, silver/blue secondary in 3rd possition. Engagement was about 4,200 RPM. This felt a little sluggish on the upshift and only pulled 7,500 RPM. I was happy with the engagement RPM with this spring for a trail spring.
HC said the primary selection I made would work for what I want to do but maybe try the black or white spring. I don't really want to go much higher on the engagement.
He recomended taking the 3.2g out of the center to get it closer to 8,000RPM on the shift out. I did and it worked, I am right on 8,000RPM on the tach. Upshift and back shift felt pretty good and on/off throttle response felt strong. Engagement went up a few hundred to about 4,400RPM. It seems to pull pretty linear and seams to backshift half way decent.
HC told me that with the 52/34 helix It would come up to 8,000 and then drop back and then climb again, meaning the engine couldn't pull the angle. So far it doesn't do this. When I lay on the throttle from a stop It cranks to about 6,000RPM and then whips to 8,000RPM on the full shiftout. Isn't that kind of what it should do?
My questions are this;
1) I have several other helixes to try. I have a R11, R32, 50/36 SLP and I am willing to try a few other profiles as well. What are going to be the caracteristics of the various helixes? Versus each other or vs what I am currently using?
2) In the instructions it said to keep adding weight to the shoulder until the engine bogs and then back it off. What does this accomplish? Should I waste my time trying it or not?
3) Should I try adding weight to the tip for better back shiftin gand take some away from the shoulder? Will this make it upshift slower and backshift faster? What will this do to top speed?
4) I still need a few hundred more RPM, he recomended trying the nest hole in the helix but I heard using the secondary to control full shiftout RPM isn't a good idea????
I'm sure I'll have more Q's as the thread goes on but this is a start.....
Thanks in avance!
Thanks in avance!
