the only thing i have changed is the main jets when i rebuilt the motor it looked as if it was dangerously lean went up 2 sizes on the mains that didnt change a thing Have the secondary apart on my floor right now feels a little sticky to me clutch setup is almond round in primary with 62 gram weights secondary is yellow erlandson with 52/34s helix, buttons where new 2 rides ago spring is in the 3rd hole.. origanally thought maybe it was weighted to heavy as this is basically the same clutch setup i have on my 03 800 I may be wrong in this but the rpms should change with altitude if it were weights and it pulls the same at 6000ft as it does at 1000ft also tied it up off the ground and it pulled up to 8250 with a slight hesitation at about 7250 wich is somewhere close to the point it wont go past if your riding it
