02 MM700 Mountain Mod
Have for Sale 2002 159" MM700, 2000 Miles, Super Clean, Est. 170 HP
List of Mods,
Boss Noss Nitrous Kit
Simmons CPR Ceramic Coated Triple Pipes
MPI Remote Fuel Screw Adjusters
Lightning Pro Stage III Cylinder Porting w/Triple Ports & Enlarged Transfers
Lightning Pro Stage III Crank CAse Tunnel Port & Side Blend W/Matched Transfers
Lightning Pro Stock Head Performance Reprofile
Lightning Pro Boost Tube Kit
Stock OEM Kinked Steering Column For Boost Tube Clearance
Machined Base Gasket to Match Cylinder To Crank Case Porting
Machined Stator Pickup For Timing Advance
Machined Reed Stoppers To Match Porting
Machined Stock Primary Clutch For Overdrive Shift
Heel Clicker Weights
Team Rapid Reaction Secondary Clutch
MPI 159" Kicked Up Rear Tunnel Extension
Camoplast 15x159x2 Track
Anti Rachet Drivers
Billet Wheels For Rear Suspension
Air Box Mod
Powder Prefilters
Flow Rite Intakes on Dash For More Air Flow
Stainless Steel Brake Line
Avenger 3 EGT'S
Rox 3.5" Riser
Boss HiRise Seat with 2 Nitrous Tank Compartment
SLP Powder Pro Ski's
Holeshot Skid Plate
Lightweight Wave Brake Rotor
MPI Aluminum Spindles
MPI Polished Aluminum Modular Trailing Arms
MPI Polished Aluminum Radius Rods & Tie Rod Kit
MPI Billet Steering Arm Kit
MPI Lightweight Rear Skid W/ Transfer Enhancement
Works Shocks All Around
Custom Rear Bumper With L.E.D
Gold Finger Left Hand Throttle
Aprox. 27.5" Rear Tunnel Height Where Bumper Bolts On
50 Lbs. Have Been Shaved On This Sled
Sled has been well maintained and I have the "BIBLE" as i call it, the manual with everything you need to know for clutching,jetting,and everything else to make her rip up the mountain. This is sled specific information for this sled and is probably the most valuable thing that sets this sled apart from everyone elses, I mean it is Like A "BIBLE", If it's not in there,the phone numbers of someone who will know is. Price Is $6000.00 OBO and it's located in South Dakota. Trades Welcome. Please Call if serious about it, 605-680-2785
