TECH TIPS 800 EDGE-X 800
I have a 2002 edge x 800 and the clutches are in need of servicing. I am looking to get more power out of the sled and I was wondering what the best clutch kit would be for my sled. I was also woundering If anybody has had experience with the sno stuff cans and is it worth the money in weight savings and is there a power difference. Also if you had to change the jetting after installing the can any advice is appreciated
I had a 2002 EDGE-X 800 that was extremely well dialed in, SLP bolt-ons, I moved the TECH TIPS thread to the top for you:
almost FREE MODS
PRIMARY CLUTCH:
1) Check your belt to primary sheave side clearance, should be .010" to .015" w/NEW belt, mine was .070" from the factory.
2) Install a new primary clutch spring @ the start of every season. (approx $31.00)
3) Send your primary clutch out to have it balanced. Since these sleds have a bad rep for wasting the crankshafts, put a dial indicator on the crank snout (remove primary) and periodically check the run-out. 002"-.0025" is the MOST I would want to see. Made a NOTICEABLE improvement in smoothness and extends crankshaft and clutch life, they drilled 8-9 lightening holes in mine, that's how far off it was from the factory!! SLP and others charge only $35.00 for this service. Do this after you've set the belt to sheave clearance.
4) FLATLANDER SET-UP FOR 800 EDGE
a) ALMOND/red stripe SPRING (POLARIS part # 7041988)
b) 66 gram stock weights, OR
c) SLP's 68 gram MTX'S with 3 grams in the tip, plus 2 to 3 grams in the middle, slight improvement over 66's
SECONDARY
Button Secondary
1) Install a new secondary clutch spring @ the start of every season. (approx $31.00)
2) Replace the (3) little plastic wear buttons, they're approx $ 1.00 each
3) FLATLANDER SET-UP FOR 800 EDGE
a) Stock SOLID BLUE Secondary Spring
b) R-49 Helix, (POLARIS Part # 5133023)
Roller Secondary TSS-98 or TSS-04
1) Install (1) DELRIN washer under the spring cup in your secondary clutch (less than $5.00)
2) FLATLANDER SET-UP FOR 800 EDGE
a) Helix 70-42.46 duration SLP part # 50-90
b) Secondary spring 140/200 Red/Dark Blue SLP part # 50-4
The old style button clutch was faster on top end
BOTH PRIMARY & SECONDARY
1) Align your clutches (offset, center to center, and check for engine "crooked"), mine and my bud's were off!!!! You may have to shim behind the rear engine bracket(s) to get it perfect. Use thin Chevrolet style starter shims available @ Auto Parts stores under the “HELP” brand.
2) Lightly sand both primary and secondary clutches w/180 grit perpendicular to the way the belt rides and wipe down w/lacquer thinner.
3) Wash/scrub (plastic bristle brush) your BRAND NEW belt w/soap & hot water, and let dry overnight, sounds weird, but it removes the "mold release" compound that would otherwise would get smeared all over your nice clean clutches.
4) I prefer the #3211087 belt, it's a CLOSE TOLERANCE version of the #3211080
