Hi I am new to the forum and also new to the turbo world, but I need some help and that leads me to you guys lol
I am building an 01 summit 800 for drags
Stock carbs (for now) with power jets
3071 turbo
Msd fuel pump
Return fuel regulator set at 3psi at idle
Greylor oil pump
Head cut for lower compression (I'm at sea level)
114. oct fuel
And more things I'm probably forgetting but my problem is iv tryed jetting from 370 main to 420 mains with power jets in every spot and can not get it to run even decent
I'm starting to think it might be the dpm so I don't know if I have my carb vent lines hooked up properly.
The Vents At the top Of The Carbs (I Believe for the dpm) I think is my problem
When hooked to the charge box runs but not very clean
When capped runs extremely rich like blowing fuel out the pipe
When left open hooked to nothing it runs extremely lean whent up to 470 mains and choke open and still wanted to cut out
So I'm stuck and need some help anything is appreciated and thanks in advance.
Also the lower vent lines where hooked to the charge box the hole time
3071 turbo
Msd fuel pump
Greylor oil pump
114. oct fuel
