M
Motley Doo
I have a 01' summit x hmk 800 that just got totally rebuilt. I put a 162 under it, had the cylinders re-nicked, RKT 82 mm piston only kit, mild porting, crank re-built, thick base gasket and a shaved head. I was up today breaking the motor in, it has probably 25 miles on it and was just breaking it in. I got halfway through the ride, after a little bit of a pull, I came to a stop, then went to get back in it, and it fell on its face. It felt exactly like when the DESS is halfway pulled off, it wouldn't run past 2,000 rpm. I wiggled the DESS plug, pulled the loom apart couldn't get it to run past 2, but when I hit the high beams to low beams for the headlight, it died, and when I kicked the grip heaters off it died. After a while of messing around, it started to run right, still missfired every once in a while, but only ran like this for 1/8 mile, then it died again. I towed it halfway out, decided to see if something had shook loose, it fired up and ran like a champ for another 7 miles until it started missing again, but now, only past 6,000 rpm, then got it to the truck, I shut it off, then I couldn't get it to fire again. All the miss fires were like a rev limiter kicking in. The only thing that I changed electrical was that I had the computer re-programmed by Ski-doo race dept. and I can't run a tail light until I get a rack. Has this happened to anyone or ever heard of it. I thought of the relay but when my buddies relay went out on his, it just lost all auxilary power, and still ran, mines the opposite! I'll start pulling the console off tomarrow to get a better look at the DESS, but I'm affraid that with it dieing when coming off of high-beams or when shutting the heaters off, I've got a bigger issue. Thanks for any help, sorry to make the post so long! Thanks!
