01' 800 Highmark Oil Question
I have an 01' 800 Highmark and I seem to have a lot of oil that comes from the Pipe. So much, that it looks like I have a leak when I'm done riding. Is this normal?
Pull the pipe and look at the seal between the y pipe and pipe.......clean well and go back together with high temp rtv at the joints. How is the oil consumption?
be sure and check your RAVE valves that they aren't dirty and sticking too~~
So, after pulling the Pipe, I found that the previous owner had installed an aftermarket pipe and can, but when he did, the new pipe didn't slide into the outer flange on the Y-Pipe, se he ground the outer flange off and slid the new pipe over it....
I've attached a photo of the end of the Y-pipe.
ya you're just not sealing at the connection. and on the Rave valve go to ski-doo's web site and go to the maintenance manuals for your make and model ~ they are free to sk-doo owners to view or download and it will walk ya through it!
I checked the site, but couldn't find anything, but i found a tube video that went into pretty good detail on how to do it. So, High Temp RTV around the outlet of the Y-pipe still?
