00 polaris 700
00 polaris 700 pics
Have a 00 700 motor head, case and crank. With bad pto rod bearing. If intrested call 406 567-2532 day 406 567 2664 nights. Make me an offer.
have left
head
main crank case
crank may or may not be rebuildable
what would have to be done to get it running?
Pull the crank and have it rebuilt. The bronze bearing on the pto rod came apart, everything else looks good. Might throw a set of pistons in it just because. I was trying to sell the sled when it went, glad i hadn't that would have been a real bummer for somebody. So i just parted the sled out instead of fixing it. I have the head and cylinders loose can pull apart and take pics if anyone is intrested.
just that bad rod bearing, i would guess that you would have to put new bearings on the crank because of the brass going through them, that is if the rod didn't screw up the crank. If i was to do something with it i would throw a crank in it and a set of pistons and go. The head and both cylinders are good.
