00 mxz need your help
B
bluemountainrider
New member
I have a 2000 mxz and it has a 121" track with a 1 3/4" lug. I want to put a 144" track on it. I found a really good deal on one that has a 2 1/4 inch lug and I would like to know if this track would work with out rubbing. I am pretty sure I could get a 2" lug under it without changing anything but would I have to roll the chain case for the 2 1/4" lug or can I go with smaller drivers. Any help would be great.
2.25"
You will need to go to 8 T drivers for that height. Also, get the extensions to put in a 136" track and move the skid back 3.75". Use drop brackets as well for the rear.
I had to roll my chaincase, drop brackets and use 8tooth drivers. It gave me plenty of clearence so the track wouldn't rub.
You need 8 tooth drivers, remove factory tunnel protectors under gas tank, you need 121 to 144 rail extensions(cant relocate a 121 skid)...call for specifics-BJ
