decided to part out my sled. it has aprx 2500 milles. in exclent shape
reason for parting out. the common problem with this motor is the single ring
pistions like to flake and when that starts to happen the pistions become to
hot and over expand and it warm seazed. this happend last sping. i been wanting
to rebuild it but i got a rev. so the top end is going on that.
parts list
intake box 30
carbs with cables 120
reeds and boots 80
y pipe 40
esaust all stock whit can 100
skid with out shocks new slides 225 325 with shocks
fornt shcks hpg rebuildable 250
primar clutch crank and case 600
secondary 100
bumper suports both 40
belly pan 125
speedo 50
tac 25
track driver new bearings last summer both 35
jack shaft 40
brake calpier with pads 70
disc brake 20
dpm with teather 125
seat good shape 100
gas tank with broken cap 75
snow flap 30
handle bars without controls 30 with controls 100
riser 3 in 30
stearing componts and front arms make offer
skies yellow flex almost new with mounts carbides loops 150
fuel pump 25
new middle of last season bought form ski doo for 115 voltage reglator 75
coil with wires 60
tunnel bulk head no exchangers bare frame polished tunnel. slight dent in tunnel can send pic i just found it. best offer with clean titile
oil tank 30
both side councle dash 30
choke cable 25
headlight 80
dash pice with lights 25
yellow center councle 30
dess switch 30
thumb warmer switch both 5
clutch cover yellow 20
rear shocks 150
belt cover 30
spindles 30
motor mount 20
rear heat exchanger 100
fornt heat exchanger 50
oil pump asy 50
i have the comple sled taring dow as i go. let me know what you need. thanks will sell as whole for 1800. other wise parting out. or trade for rev chassis summit 144 or 151 with track skid a arms handlebar controls speedometer maybe speed sensor. i have a 03 mxzx 600ho that could use a new chassis mine is bent by the primary clutch. let me know. the only thing this sled wont come with is the chain case and top end. going on my rev. would like to keep the hood if posible.
all parts are best offer prices are form ebaymotors
email for pic. it is all yellow me edition hotrodbrett1@yahoo.com
my number is 507 398 3374
parts list
intake box 30
reeds and boots 80
y pipe 40
secondary 100
belly pan 125
speedo 50
tac 25
jack shaft 40
disc brake 20
seat good shape 100
snow flap 30
riser 3 in 30
fuel pump 25
coil with wires 60
oil tank 30
choke cable 25
headlight 80
dess switch 30
rear shocks 150
belt cover 30
spindles 30
motor mount 20
oil pump asy 50
