C
Having electrical issues with the boost, curious if anyone has any input on where to direct the dealer.
First symptom was the 7s display staying on, even when key was turned off. Had to unplug connector under the hood while parked in the garage to prevent battery drain.
Forgot to unplug it on a long road trip, ran the aftermarket battery down and cooked it. Rode 3 days, basically like a sled with no battery.. everything shuts off when engine shuts off, otherwise ran normally.
Take it in, they replaced ignition, said it was a short in there. Put the OEM battery back in, seemed fine at first… Then first ride out, it’s acting up again.. same issue but now throwing loads of electrical codes, randomly bogging mid pull and totally dropping rpm / power.
Runs fine and super crisp on the trail, get into WOT in deep snow, sometimes it can pull 1-2 mins normally but eventually throws codes, just a matter of how long it will go. Sometimes 10 seconds after shutting down and rebooting display by unplugging.. other times takes 4-5 mins to appear but it only happens off trail.. never on.
Don’t see any loose connections or damaged wire but something is clearly shorting out.
Any ideas?
Any ideas?
![de18662491d4c7d7ce404483657924ea.jpg](http://uploads.tapatalk-cdn.com/20230222/de18662491d4c7d7ce404483657924ea.jpg)
