We just finished up our e-start(shot) system on our Alpha. We ended up cutting the two battery leads shorter to make the install cleaner. Theres quite a bit of taking pins out of plugs and installing pins into plugs. For those that think it may be a easy swap from sled to sled. It's not. Unless you're ready to swap out all the wiring harnesses. We used the stock battery holder and bent it to fit our Ucap. It fits under the hood perfectly. We also put the starter solenoid in a reachable location, if we ever need to jump the sled. The reason we jammed it all under the hood as I didn't want the bigger seat.
