Thought this would be a good thread to start. In the test ride reviews it was mentioned several times shock settings will be super critical for the Alpha. This will be a perfect spot to share settings and talk experiences.
I do not have anything specific to share yet. However when I checked pressures from the factory/dealer the rears where very close to what I used on my past sleds. I had to slightly increase both as I’m likely above the average rider weight. The fronts are where I saw a huge difference. Typically I run 60-65 in the front. But they came at a 100. At first I thought that is way to much but the more I thought about it, I’m curious if the fronts will need more pressure then past sleds due to the mono rail and overall the sled being easier to tip. Anyways look forward reading what everyone is finding throughout the season.
As with past shock pressure threads, give some stats; rider weight, track length, typical snow conditions, HP mods, etc....
Let it snow!!!
Let it snow!!!
