If you would like to change your older P85 Pro ride clutch to work like the New Axys clutching we can do that...Here is what happened. The Pro ride has a step in it and the sheave angle is 14 degrees both sides. The NEW Axys primary clutch is at 13.5 degrees with NO step. The new angle allows for faster shift out and the belt will ride higher on the sheaves thus making a few MPH faster on top end..
We can cut your clutches to the new 13.5 degree Sheave angle and re-shim your clutch as you will need that done because the clutches close, closer together now...
The new Axys belts #3211177 are at 26 degree to compensate..
