I am completely blown away at the continuing issues that I have been having with these EXPENSIVE trailers and its time we raise some cane!
I bought a new 2016 Trailswest RPM Burandt with all of the goodies. I had the heater go out twice, both times the dealer took care of the bad circuit board issue. They never installed foam on my rear door so when I get to Idaho to show off my new trailer, my buddy says, as we open the door, " did Trailswest include the snow at no charge?" There was a 3' high pile of pow in the corners of the inside of the trailer!! Both of the door locks for the fuel doors are somewhere along the highway between my house and The Snowies; both fell out. Then, the side panels of the trailer started to "unseal" leaving the skin opened up for debris and water to get inside! That is a bad idea because it will freeze and make the issue worse. Trailswest paid the dealer to re-seal the seams. The trailer was 2 years old at this time so I was thankful for the warranty. But, it looked like poo poo after the seams where "re-sealed". It was very obvious that they had worked on the seams.
So, I sell that trailer and "upgrade" to a Logan Coach Zbros trailer all loaded up-$39k. The first trip home I go to wash it and the back door seam has failed!!! I call and raise some cane and back to the dealer I go to have them rivet that seam so it wont happen again. This morning I go to wash the trailer and see that 3 of the seams on the passenger side have failed and are opened up!! WTFruit!!! This should not be happening on a brand new $39k trailer! This 3m tape is JUNK!!!!!!
As for the Logan being a better built trailer? Dont fool yourself. I have had it back to the dealer because of the failed seams, a stereo and amp that was not hooked up right, and rivets falling out of the walls because of some zipperhead at the factory doesnt give a rip about what he is doing.
I also have two buddies that have 2018 Burandts and both of their rear doors pulled apart and bubbled( Trails west installed new doors) and on one of the trailers they flipped the exhaust ports(at the factory) of the two heaters causing the main heater to not work. As a business owner, this stuff is insane to me!!
Please go look at your trailer and see if the seams have opened up. If enough of us holler back, maybe they will change their ways.......... probably not, but worth a shot.
