I have came up with a design for a fold down bench for an enclosed snowmobile trailer. Depending on how much you find the parts for they cost around 25-80 to build and work very well. I will post a video later today on how the work but here are a couple pictures. There is one snowmobile part used anyone recognize it?�
So so basically I use 1.5" angle iron to use for the mounting attachment on the wall, the ctc is perfect for the studs. Then use 1" light wall square tube to for the front leg. To keep it from slipping out when down I drilled holes through the floor and screwed big fender washers, then welded 1/4" bolts that stick through the bottom leg and go into those holes. To keep it in the storage position just use more angle iron and a tarp strap to hold it in place. The top of the snowmobile part is covered with 5/8 plywood, then wrapped with cheap indoor/outdoor carpet and carriage bolted into place. Easy to build and works great. Reason I built these I didn't like the price of anything on the market. I will post all the dimensions on the front leg and pictures of how to weld up later. Just helping out fellow sledders. Oh yeah and if you haven't guessed what part it is it comes in various lengths. Lol. Cheers
