For those wishing to this, I've found an AC Delco pigtail that plugs into the headlight harness.
Here's the info if you have an AC Delco distributor in your area:
Item PN: PT996
GM (OE) PN: 15305839
The connector is a Delphi Metri-Pak 150 connector, PN: 12162102
If you want to buy the connector parts separately you will also need the following:
TPA Secondary Lock: 12047948
Teminals: 12045773 (16-18 gauge)
Cable seals: 15324973 (Dark Red - 16 gauge), 15324976 (18 gauge - White)
Cable cavity plug: 12059168 (Dark Red)
Item PN: PT996
