Well I just got my art work in from B&M and thought I should share some pictures and get the word out! The fabrication on these is simply beautiful!
At this time, these are a Limited Edition run as the Labor and material makes the pricing higher than the standard tube board. These LE boards have a machined Flat piece that bolts to the tunnel instead of the tubular setup that rivets to it.
I have got a set myself and will do a install write up on here with some pictures and maybe a video.
1: Notice the taller foot well loops. This will aid in less knee and ankle injuries caused by your boot getting stuck in the stock arrangement.
2: The larger spacing reduces snow build up. The machined flat back holds virtually no snow compared to the stock boards and the typical round bar used on other designs.
3: Much stronger design than the stock setup. The machined flat back provides strength to the tunnel.
4: With traction screws installed, they provide an increase in traction during all conditions.
These are simply Bad A&* looking and can be shipped powder coated!
Call B&M today and ask about the LE Axys boards!
612-202-9245
info@bmfabrications.com
Quantities limited!!
612-202-9245
