SKINZ DAN ADAMS NXT LVL FRONT BUMPER
I've got that bumper as well. Looks good and well built for strength. My only complaint is that the bash plate holds snow between it and the sled. I wish the bash plate was on the front side of the bumper tubes so snow could have more room to fall out.
Ya I can see that happening but not really worried about the little weight it may add.. Can always take it off if need be..
those are sick! Ill be sure to put one on my 2015....(unless another sled manufacturer really surprises me)
I assume this mounts to the overstucture the same way as previous skins bumpers ? I need to replace my aluminum skins bumper its done its job but it is beat.
It comes with 4 rivets to attached the bottom but I used to Carriage bolts instead..
Front and rear going to look good... Well done!
Ya I can't wait to get them. Been a long wait for the rear bumper. Looks good on your sled! Nice wrap also. The description I read on the front bumper it said you have to cut the skid plate to make it work but I suppose bolting vs riveting allowed you to mount it on the outside of the skid plate without any cutting?
I put both front and rear on, Thinking of putting a piece of hard foam in between the front plate and belly pan to keep snow/ ice out, first couple rides it was packed in, really doesn't hurt or affect anything but figured I'd try that.
Any reason that you couldn't line up the bash plate on the front, drill and tap some holes in the upright tubes and install the plate on the outside with some small bolts?
I think this could be possible. When I got my bumper the bash plate came separate and I had to drill my own holes and rivet it myself, PITA.
I believe you would have to flatten out the angles on the bash plate and it might work. It would be a lot better about letting snow dump out if you could do it.
Anything is possible if want it.. It holds a very small amount of snow and as of now is no worry for my... Love this bumper!
The down tubes them self hold snow all on their own.. We have a Polaris style one on our Pro-R chassis and it does the same thing..
