K
is there much or any difference between the 07 and 08 700 motor thanks?
They may have updated again, 07 and early build 08's had a double then went to singles for the late build 08 and 09's. Not sure why BD says to use the singles but I've had great luck with mine so I'm not going to mess with it until BD says otherwise.I looked on the online Polaris parts site and 2007, 2008 and 2009 all show dual rings for the 700. Are you guys sure about the single rings in 2008?
3) RK Tek: Single ring.... Single ring set-ups are great for making power in high rpm engines. In fact, in low rpm engines also, for that matter. What a single ring is NOT good for is transferring excessive amounts of heat. The ring is overloaded with heat and can not adequately transfer the heat from the crown. DOO has made the ring very thick in hopes of alleviating this problem but it is not doing the job. The ring is simply overloaded with heat!
