Here is some pics of our kits. if you would like to see more go to our website www.turboboyz.com.
In out kit you get =
Handle bar mounted fuel pressure guage
handle bar mounted boost guage
1-1 fuel pressure regulator with already installed fittings
all clamps & 4 ply silicone hose couplers
Power jets and fittings
micro boost fiittings
Garrett 2781R or Aerocharger 66
Turbosmart blow off with custom built spring
Boost hose
2" x 18" charge turbes,
2 1/2 down pipe
exhaust intake
Boyseen turbo spec reeds
10 psi waste gate accuator or 7psi you choose
fuel return fitting
High flow fuel pump capable of running up to 500HP
Avation 10,000 hr oil pump
Braided stainless steel oil line
Full instructions
Exhaust valve bellow fix
Zip ties
all bolts and nuts
custom built Baffled oil tank (that will keep oil where it should be)
Intake boot girdles (to keep boots from delaminating)
Rivits
custom built fuel pump bracket (No worries of drilling through heat exchanger
2" & 2 1/2 double ribbed constant tension clamps
gaskets and glues
Stainless tie wire
Custom built and flowed air box
Basic clutching
jetting chart for elevation
Customer service and people who care.
With the Turbo Performance kit you do not have to cut or weld to fit any parts on the sled or turbo kit to make them fit. this gives you the capability to take the kit off and put the sled back to stock if you want. These are the cleanest most advanced kit ot there. We were the first to turbo the xp and have a proven track record with many kits on the snow.
Oh by the way watch for turbo performances release of the 800 E-TEC turbo kits comming very soon!!!!!
Boost hose
2 1/2 down pipe
exhaust intake
fuel return fitting
Full instructions
Zip ties
all bolts and nuts
Rivits
gaskets and glues
Stainless tie wire
Basic clutching
