I'm trying to dial in my 2004 Polaris RMK 800 (SLP twins) with a 174x16x2.5 track.
It has 7 tooth 3.0" drivers. 19/43 gears.
Brand new primary from IndyDan. Currently have brand new Polaris Almond spring, 10-58 weights (balanced & good bushings).
Secondary is TSS98. Team black/purple spring (new). Helix is 60-38-.36 ER.
New Poo 080 belt.
It will pull RPM on the trail, 8100RPM. Not quite pulling that RPM in off trail or up hills, more like 7800.
I have run it like this with 64-40-.36 ER and it was not pulling RPM on trail or off trail. So it seemed to like less helix.
Should I try less helix yet? This thing pulls very hard on the trail when it will tach, I'd love to see that in the deep or up a hill!
I keep reading about the BB 800 needing helix angle, but thats with smaller track sleds. This thing is loaded. Revs correct with less load, not when under more load.
Engine is running well, VES valves clean w/ new bellows, light springs, crank fresh, etc. Timing may be a little retarded. Going to check tomorrow. Think this could be killing me?
I'd like to hear what some others have seem as far as clutching NA sleds with big tracks and low gears.
THANKS
New Poo 080 belt.
THANKS
