P
I have searched and found nothign for the removal of the diamond drive with reverse. I am going to put the Attack 20 on the big kitty and last night taking apart the sled, I pulled the break caliper apart, I believe there was a total of 4 allen head bolts, then the rotor came off, then I took the 5 bolts inside the tunnel off so the whole brake unit would come free. Then I went to the diamond drive, took all the little torq heads screws and pulled the cover off, then I took the 7 or so 1/2" nuts off the part the cover goes on, then I took the bolt off the reverse actuator, then the reverse actuator came off, then I slid the driveshaft to the brake side and took off the driveshaft. Is there an easier way to do this? I heard this should only take 10 minutes.
I will be pulling the attack off of the M7 tonight. Is there a certain way I should do this to make it easier? I know it doesnt have reverse.
