It seems like my sled could really use the help of one of these kits but I can't decide which one to go with, I know more people are running the RKT kit but I have heard good things about both.
hey need - post up your current setup for clutching please...
bone stock w/ just 55/65s i think, right?
To keep it simple, why not try a different helix with a shift assist to start with? try a 42/36 from BDX w/ a shift assist in the old helix style with their conversion kit. should run about $100 total. If you aren't happy, then maybe try the a torsion kit. I'm of the feeling that torsion kits provide more consistency in shifting, but i don't think you'll find a huge gain in track speed over a good setup of factory parts. just IMHO.
Running any torsion kit is going to require some other tuning as well, usually less weight in the primary and possibly a different primary spring.
basically what you are looking for is the ability to maintain good backshift single and secondary belt grip without having the same force stop your shifting. the shift assist will help and its only $20. A different helix will also help keep thing progressing too. perhaps even a 42/36 progressive.
Remember you regeared so your secondary is shifting out further at the same given track speeds as before (45mph), so you are compressing that secondary spring even more than before, so you'll need to give a break with either less angle on the helix or softer spring or something to make it shift easier (shift assist).
Also, how are your clutch temps? Both hot or just one? which one?
