I am wondering who else has had the oil reservoir opening warp and start leaking oil and who else has fuel dumping out of the fuel vent, located just above the shock, when you park at a slight down hill angle.
These are not normal issues that one should have with a new/newer sled. I know there is the aluminum ring to install on the oil reservoir to fix that issue but I think BRP should be installing that if it's as much of an issue as I have read about (without any damage from your knee).
I have been told there is a valve that possibly could be bad on the fuel vent but I'm guessing a better fix may be to run the vent line up through the bars and back like it used to be
So if you have 2013 (I have 2014 XM) and newer and have had these issues chime in please with dealer experience and/or your fix. I know not expensive fixes but it was a $13000 sled..........
Thanks
Thanks
