polaris 03 rmk 800
E
Jan 8, 2011
3
having to change out my chain case because my bering went on my drive line shaft wondering if there is any special procedures i need to do or if any of you have any time saving tips
Mark's RMK
671
76
Sturgeon Lake, MN
Chaincase
My first recomendation is to get the 2004 version with the phantom brake caliper.
Much cleaner look plus you get a double acting piston on the brakes.
I did it to my 2002 and 2003 Edge sleds.
Loosen your track all the way. Take chaincase cover off. Take brake caliper off chaincase and tie up out of the way.
Take both sprockets off and remove.
I think there are three 9/16" bolts holding assembly to the bulkhead.
Whatever you do as far as upgrading, put new bearings and seals in while you have it apart. In fact I would drop the skid and replace the driveshaft bearing on the speedometer end while you are doing this.
Then you'll have some peace of mind as you ride.
E
Jan 8, 2011
3
thanks man that helps alot i have all new bearings and seals but now im having trouble finding a drive shaft the old one is pooched from that bearing on the clutch side going know of anywhere to find an aftermarket one or just stock for a good price?
