Ok, both my brother and I had our '09 D8 puke the top end at the same time (within a week of each other). Tri-City kicked azz to get us back on the snow and we rode this past weekend.
In the meantime I had purchased a PCIII from SLP with their single pipe map in it. After talking to some people I decided to run it on the stock motor with the stock pipe to see what happened.
The 2 sleds are set up identical. We rode in 50 degree weather at 9800 feet on Saturday.
1 - The PCIII sled pulled 200 rpm more than it did before putting the PCIII on it.
2 - The PCIII sled had better throttle response out of the hole and pulled harder through the midrange. They felt the same on the top end.
3 - Before putting the PCIII on I had noticed a midrange gurgle. With the PCIII this gurgle was gone.
We didn't compare fuel mileage, but it was pretty clear that the PCIII with SLP map helped the 800 out some. I would imagine you could get a map that was designed expressly for the stock setup and get good improvement out of it, but even using the SLP single map helped.
sled_guy
sled_guy
