Has anyone come up with any brilliant solutions to the snow build-up between the bulk had and belly pan that interferes with steering?
In addition to hard steering it also adds around 10-15 lbs of unwanted weight right under the motor...lame!
So far my best ideas are trim down the oem belly pan so it doesn't have the "ears" that are on either side of the support beam, basically making it a smaller floor for snow to sit on. also I'm going to spray clear coat on the aluminum to create a less bondable surface for the snow to stick to. Then probably will spray everything down with light grease whenever the snow is deep and wet...
any other thoughts....
