B
When in doubt go for a new set of eyes. The bad news. (I'm going to try to keep it short) Out riding and let my 2003 700 SKS buck, brought it up to a good clip but it didn't want to take right off, she hung around 70. It seemed like it was a clutch issue so I let off and then stabbed the throttle again and it took off. Played for a short bit, dove off into the snow to cool her down and then came back out on the trail. Stabbed it again but couldn't come close to the speed I was just at. I was forced to finish the trip to get it back out to the road, by the time I got there it wouldn't go more than 28 MPH and it wasn't missing as much as it was limiting. Here's what we've tried.
Carbs, clean nothing missing
Changed plugs, cardboard brown in color, same issue with new plugs.
Black wire unplugged to remove all the switches from the troubleshoot, same issues.
Brand new temp sensor, same issue
ECU from two different sleds, same issue
CDI (coil and wires) from a running sled, same issue.
Service manual, Checked the ohms per the service manual for the coil, stator, and all electrical.... Nothing tested bad.
Tested the Throttle position sensor, tested good with the polaris 9v tester.
Exhaust valves removed, looked good on both.
Timing check, 10 degrees roughly at idol, bouncing all over at wot as the sled seems to be limiting all the time when you give her.
Took out the bore snake camera, top of piston and cylinders look good, skirts look good, rings and all that look good. Pulled carbs again, reeds look good, scoped lower end and everything looks good.
Both primary and secondary clutches just came back from SLP this year and have been great, the mechanic helping me thinks hands down electrical.
My friend is a Polaris mechanic helping me. He's going to call tech this morning to see if they have anything to help. I'm going to the Forum for a fresh set of eyes.
Thanks for any help in advance.
