D
Welcome to almost-winter 2015 folks! It's been a wild ride since ol' Mother Nature was coating our mountains routinely with snow, but now it's nearing ever closer once again. Random cold snaps and an impressive dump nearing 20" of snow on the north faces of Lone Peak several weeks ago has spurned enthusiasm from the local sled crowd. Having just returned from the Big East Powersports show in Syracuse, NY, it's now a great time to enlighten fellow Sledheads with good news from Dynojet.
As it was all the rage in the hands of show-goers in NY, Instead of saving what might be best for last, it’s going to lead off our story.
Introducing the C3 Mobile Application for your Android Phone! Dynojet is proud to avail tuning for Power Commander Products from your phone. This app is available for free download on Google Play enabling users to send any map stored on your phone to the device, adjust fuel trims in the field, calibrate throttle position, and many more things all from the palm of your hand! Now, if you're in the mood for adjustments while out riding, simply send a new map to your fuel controller from your Phone, or (if in cell service range) give a quick call to your supporting dealer who can email you a new map and load that one! It requires a USB-On-The-Go adapter to connect.
Yamaha has been kind to us across their lineup allowing customers to choose long/short tracks, red/blue colors, 2 or 3 or 4 cylinders, and of course - boosted or non. With all the combinations, this brand is privy to a massive selection of our goodies to get the most out of each ride. Ranging from a simple PCFC for your header and exhaust mod, or going hog-wild with a PCV module on your turbo machine, we've got you covered. In fact, we've pigtailed out a 4th injector for your factory Viper turbo runners for full control over that system. Thus, don't run out of fuel at 6-6.5PSI even when at low elevations - but turn that bad boy up to 8.5PSI by having full control over the stock 3 injectors. After that boost level, now we can start kicking in the 4th injector running up to 12PSI easy-peezy. Check out all the testing of this upgrade done by Ulmer Racing on the TotallYamaha site to make your Yamaha run like a champ. Not to stop there, the Dynojet Ignition module for Yamaha Viper provides control over the spark timing, And can raise that pesky rev limiter allowing you to hammer the throttle without popping the limiter so low in the powerband.
Across the rest of the product line we've worked to beef up our offerings in every brand, while our fabulous and loyal dealers keep pushing hard to add more performance to your ride. Compatible with Power Commander Products for all makes and models, The POD-300 digital display gauge still remains wildly popular among all enthusiasts from dirt to road to snow. This little gem is loaded with features including a real-time gauge display, in-field fuel adjustments, data-logging, and even flashes warning lights when parameters chosen by you are met. The next highly useful tuning tool is the Autotune or Wideband2 device optional to add to any PCV. Whether you just want to monitor the air:fuel ratio of the exiting exhaust gases, or have the device build you a map for you as you ride in real-time, the Autotune is immensely helpful. Simply input the desired AFR you want your engine to run at any operating condition of Throttle Position, RPM, or Pressure - and GO RIDE....that's it. It'll build the map for you adjusting the fuel trims along the way to meet your specified AFR value.
Come see me at the Intermountain Snowmobile Show in Salt Lake City on October 23-24 with any questions or to just say Hi! Check out our website at www.powercommander.com for more information and a complete selection of all our applications.
It's Time to get Excited for Winter!
~T.J.
~T.J.
