Clutching Help?
T
Oct 12, 2008
41
1
8
34
ND
Ok, I have some questions. I have a 2004 King cat carb. Mostly stock engine. Clutching is all stock currently and i have 19/42 gears in it. It will do 7800-7900 rpm's on any pull which is great and has lots of power. My issue is that it seems to me that i am lacking something as far as clutching. I believe my issue is that my clutches are back shifting and taking away track speed to early. This is brought about by the fact that it a climb i seem to lose speed rapidly while the engine is still at 7800-7900 rpm's and doesn't get pulled down at all. Does anyone have some advice on how to address this issue. Should i be changing primary weights? Or do i want a different spring and helix in my secondary? Also i am currently running a straight 53 deg helix in secondary. Any help is much appreciated. Headed west after the first so looking to make changes in a hurry. Thanks!
D
diggerdown
3,452
677
Deer Park Wi.
Take some tension off you secondary spring. 5 holes in the cover plate, go counter clockwise to up shift quicker and backshift slower. If you run out of holes put a lighter spring in it. The 900 was generally set up to run around 7500 R's, so you could try more weight in the primary and see how it acts.
T
Oct 12, 2008
41
1
8
34
ND
thanks digger im going to have to get some weights ordered up. probably going to go with adjustable weights since im not quite sure what i need. jizzle i ave heard for a single pipe 7500 to 7800 ish is where you want to be for the best power. 8100-8200 is usually where twins make good power i believe. some one please correct me if i am wrong.
D
diggerdown
3,452
677
Deer Park Wi.
You are right on the R's, didn't know you had a pipe on it. General rule of thumb is 1 gram of weight for every 1000' of elevation...with lots of variables!
2
41
Kent,Wa.
weights?
I got 77g's in my 05, turn my sled 75-7700. Lots of variable though? Id say put some weight in. I also didnt like the adjustables, they had a differant profile and were very touchy on engagement. I like a smooth engagement and a good hit on the bottom. I ride 3-6k here in the NW on heavier snow type. I have an all stock sled except for some clutch tuning and some gearing. I would buy a gauge with a J/S sensor. best money I have spent yet! -Good luck and Merry Christmas -00's
1Mike900
996
169
Bellevue, Wa
2Z what is a J/S sensor? Is it a jackshaft sensor you are referring to? Wheres a good place to get one? Thanks Mike
