Pro & Cons
Pros 153 Powerclaw, M1000 - Timbersaled Mountain Tamer Rear Suspension
-Incredible Powder Performance & Flotation
-Very Maneuverable in deep powder
-Good all around length
-Very Forgiving in light Powder (No trenching tendencies)
-Tree Riding Powder- good flotation while making variable track speed & throttle adjustments
-Hooks up on trail fairly aggressively
-Softer Paddles & lug pattern requires less rider input (not by much over extreme, but is noticeable)
156 Extreme- w/ TSMT
-Favorite all around length for maneuverability & stability in all conditions- specifically aggressive traction is this tracks best attribute & about an 7or 8 (1-10being the highest) on flotation capabilities in light bottomless powder
-Does decent in the light powder, however higher moisture content powder performs great
-Throttle adjustments needed in light powder as to NOT trench (however, still will go good)
-Very aggressive for icy conditions (hooks up)
-Does good on trail (recommended 60MPH max as not to tear stiffer lugs)
-Spring Tree riding or set up snow (icy tree wells ect) AWESOME performance
-Great for Chutes style climbs (paddles do not fold over under full throttle) & variable snow conditions & seems to be consistent handlebilty through changing conditions
-Very stable descending (esp noticeable in icy conditions) almost feels like break is on under certain spring conditions
Cons 153- Powerclaw
-Fast on descents & wants to break traction & bring the rear of the sled around
- Not good on ice, or very hard packed snow...will slip out while climbing
- Under full throttle on set up conditions can be a handful if to much body language input is given while climbing, tends to want to over react to side-to-side input,
Cons 156 Challenger Extreme
-Harder Lug makes light constancy powder riding more difficult
-Lugs are easier to rip because of stiffness & do not give (mainly be aware when crossing creek, again high speed on trail, ect)
150 Extreme M8 w/ Mountain Tamer Suspension
-very similar to M1000 156
- faster response to rider input than the 156 M1000, however with the M8 power band can be more challenging in light tree powder riding
174-Extreme M1000 w/ Mountain Tamer Suspension
-Deep snow & Steeper Climbs are this tracks attributes
- Can wear you out in hard spring condition tight tree riding
- good for High Boost 4 stroke sleds
I have been happy with both tracks. However the Extreme is my preferred choice.
