Boondocker Nitrous Question
M
mattern
New member
Dec 17, 2007
45
1
8
41
Right now I have my nitrous manifolds installed into the boot that connects to the throttle bodies, and i also have the speedwerx lightweight air intake so I also had to install the air sensor in this boot, and the nitrous doesn't seem to be running right, could it be that the the sensor is picking up the nitrous and cuttin the fuel off??? should i move the sensor somewhere else??
savedbygrace
189
Idaho Falls, ID
www.boondockers.com
It ‘s unlikely that your air temp sensor location is the problem. If the nitrous manifold is mounted so that it sprays across the opening for the throttle body it can actually block off air flow through the throttle bodys, while spraying. It’s best to have the manifolds positioned so they spray toward the throttle bodys rather than across. You may need to mount the manifolds further back in the air box to accomplish this.
Junior
