G
Oh smarter and more experienced people than I...
I have a 97 RMK 700, it has twin SLP pipes, geared down, stock clutching.
This issue has been noticable since I went back to stock clutching, well more so.
Well.. ok..
Last year I had the clutching done, I had an almond square in it (came with the sled) but the clutch was engaging to high for here I was riding so I was constantly on and off the throttle to keep from hitting things like trees... so I had it clutched back to stock. Now it's had less than 20-30miles put on it since cause it drives me nuts.. I'll be riding, stop to cross a road or slow down turn and start to go up a hill, and it'll bog it'll rev to about 3500-4000rpm and sit there, it won't spin the track so I have to get off, hold the throttle and walk/push it where I want to go, once I get back to flat land it seems "normal" again.
Now in trying to figure out that issue I discovered another issue... I think they might be related. When I fire up the sled it only runs on one cylinder. the clutch side cylinder doesn't fire. Once it warms up a bit it'll start to spit and pop (actually blew the snow out from under the exhaust once and started a fire) then the other cylinder will kick in.
I tried new plugs.. helped for about 1 short ride. The plugs get pretty black pretty quick. Both plugs look identical.
So the yesterday I did a compression test.
75psi on the clutch side cylinder, 90 on the other - dead cold, hasn't been run all summer.
I started it, let it run long enough to kick in the second cylinder, then let it run for another 5min... no change, compression still the same.
So I have no idea.. I was thinking maybe the coil pack or whatever it is called on the sled.. but it's like my wife's car 1 pack for all cylinders, not like my truck 1 pack per cylinder.. so I was thinking that's probably not it.... as then both cylinders would have an issue.
The one cylinder fires pretty easy, after the first start of the year.
Any help would be great.
Thanks
Well.. ok..
Thanks
