Here is what worked for me.
Howdy, looking to put a new track on the old 04 900 159" and would like to put on the new power claw. Is possible? Do I have to buy new rails or does someone make extensions for something like this. What will I have to do to the drivers or skid height? I've heard alot of good stuff about this track so would like to have this for an option. Thanks for any input or advice.
I just changed from a 159" to the PC and here is what I did:
1. 9 tooth, 3" pitch extrovert drivers for an 1 1/8" drive shaft.
I cut about 2.5" off my rail tips to get them to clear the drivers.
2. anti-stab kit
3. Mountain Machines "Freedom Axle", It gives you the option of running the two wheel set up and in doing so, offsets your wheels back 2.5" which take up the slack from going to a 162" track.
What I learned here was that this kit requires 25mm wheel bearings and you have 20mm bearings, so if and when you order this kit make sure you specify.
Your other options are to relocate your rails back about 2.5", but you still need to change your drivers or to look into KK rails and different drivers.
I'm loving this set up. I've been on three rides since I changed and it seems like I'm on a new sled.
