Есть такая проблема. Работает реверс, но ошибок на дисплее нет. От кнопки Shot не заводиться.Загруженные сани, чтобы покататься, поехали в сноу-парк и дали саням разогреться. Снял ехал выстрел сработал один раз потом ничего! Sled имеет код ошибки напряжения датчика ACPS вне допустимого диапазона. Цепь 1 или 2, если кто-то видел, что эти сани все еще едут и будут стартовать на тросе. Реверс еще работает.
There is such a problem. The reverse works, but there are no errors on the display. Do not start from the Shot button.Loaded sled to go ride drove to snow park and let sled warm up. Took off riding shot worked once then nothing! Sled has code for ACPS sensor fault voltage out of range. Circuit 1 or 2 anyone seen this sled still runs and will start on pull rope. Reverse still works.
Трэшь да же на новых санках ломается?Мой снимок G5 не работает. Плохой конденсатор. Дилер сказал, что они снова заказаны (кажется, это тема для всего в эти дни), но будут в конце этого месяца.
I bought my Shot on Aliexpress, the price is $ 1200. But it turned out to be defective. Now there is a question of a refund, but it is very problematic.I wrote about this on a different heading.Ask if someplace could repair the capacitor,some wrote back and said that it wasn’t a problem,I had two fail on the same machine,first under warranty the next one I bought,$839.00 I believe is the Price on Ski doo and the same on partszilla ,it all ok until you buy them out of warranty
If there is an answer on repair, please let me knowThey are replacing mine under warranty. But mine was similar to the OP. Worked all morning then around noon it just quit. I would have to imagine that if it was cheaper to repair, the dealer would do just that but I have no idea. At least I’m still able to ride. This happened with around 700 miles on the sled.
That is what I have been told as wellMy experts said that it is impossible to disassemble the Shot
