A
Hey guys. Need some help. I have a 2015 Polaris Indy 600 that I can not get to idle. Have tried a new stator because the crank position sensor was bad but it still will not idle. I have Digital wrench so I then tried the TPS. I adjusted it with Digital Wrench and still nothing. When it is cold it will idle but after running a bit it will die. It will run slow enough that the dash lights go out till it dies. The only code that it throws sometimes is the throttle stuck code but not all the time. Other than that, it doesn’t throw any codes. I don’t know what else to check. Any ideas?
