2014 Yamaha Viper - "Updated Info"
27,447
Just came across a great little article over at SNOWGOER Magazine.
http://www.snowgoer.com/snowmobile-news/yamaha-updates-sr-viper-snowmobiles-before-production/0922/
Yamaha Updates SR Viper Snowmobiles Before Production
Other than the change of front shocks, you won't see many of the updates to the 2014 Yamaha SR Viper snowmobiles until you start removing body panels.
By John T. Prusak, Editor
September 22, 2013
If you went to the spring snowmobile shows and took a real close look at the all-new SR Viper snowmobiles from Yamaha, you may want to go take a second look at the upcoming fall snowmobile shows.
After an extended spring and early summer of testing across North America, Yamaha has updated several areas of its new flagship snowmobile line, according to Yamaha Snowmobile Marketing Manager Wade West. The changes ensure that every Yamaha meets the company’s high quality, durability and reliability standards and will be reflected on the Vipers that will be rolling down the assembly line at the Arctic Cat factory starting in a couple of weeks, West said.
For the uninitiated, the SR Viper line was announced last spring and will utilize the 1049cc Yamaha triple formerly found only in Yamaha FX Nytro snowmobiles, along with the Arctic Cat ProCross chassis (called the SRV chassis when in a Yamaha). The machines will be built at the Cat factory in Thief River Falls, Minnesota, and will be quite similar to Arctic Cat ZR 7000 models with the same engine and chassis combination. Differences do exist between the Viper models and the Arctic Cat ZR 7000 snowmobiles, however. The previously announced differences include the use of brand-specific clutching and gearing, plus differing tracks, shocks (in some cases) and body work/paint/graphics.
This is a story best told with visuals, so we’ll let the photos and captions tell the story. Click on any photo for a more up-close look.
Yamaha insisted that its own clutching accompany the 1049cc triple when placed in an Arctic Cat chassis and painted blue or red, saying its clutching approach is better suited to a four-stroke powerband. After summer testing, Yamaha has a new belt to better match the new center distance of the clutches in this chassis.
A bit of good news: That belt (8JP17641) will retail for just $100
Yamaha also wanted upgrades in the chaincase.
Vipers will have the same 13-link Borg Warner chain that’s used in Apex models, a manual chain adjustment (the gold-colored bolt) instead of Cat’s automatic tensioner system and billet gears instead of the cast gears previously used by Arctic Cat in this chassis
Yamaha wants to get a better grip on the RipSaw 2 track, so it is going with extrovert drivers to reduce ratcheting and help prevent chaincase failures.
Yamaha SR Viper models will come with aluminum tunnel protectors directly from the factory.
Stud away, if you are so inclined.
Yamaha also says the protectors will reduce track slap and provide more structural rigidity to the tunnel.
The seat on Yamaha SR Viper snowmobiels will feature slightly softer foam than what was shown and tested last spring, along with a thicker seat pan and a new latch at the back of the seat with a bolt and a lever.
To improve the look of the machines to the outside world, Yamaha is going with a black radiator instead of an unpainted aluminum radiator up front.
There will also be more protective hood screens on the Vipers.
SR Viper SE models that were to come with Fox FLOAT 2 shocks have been upgraded to better Fox FLOAT 3 shocks up front.
The 3 version comes with a Kashima coating for less friction and a Samurai Sealing System that pledged better durability.
To stabilize the brake caliper, Yamaha has added a new bracket to its SR Viper models.
T
TRUEBLUEMAX
751
280
Hooper, Utah
I saw all this stuff yesterday and it's interesting to see how Yamaha is making Cat raise it's quality level to match what they are used to producing.
This is just another example of why I think this partnership will end up being a good thing for both companies.
27,447
Agreed.
I still look at this new joint development in a very positive light.
These small changed show clearly that YAMAHA has some very specific standards they expect to be met. Standards that have become core reasons why we love this brand of sled!
RACINSTATION
7,503
3,459
Idaho
It's all good, except for the painted intercooler. The raw will dissipate heat better. Upgrades like these are great and it is good to see a pro-active approach from Yamaha.
27,447
just make them in a 163 and factory turbo at a lighter weight and ill gladly go back to Yamaha again....
Lighter Weight.
The HOLY GRAIL of snowmobiling...:face-icon-small-hap
Factory Turbo, that I think we will see in one form or another...
27,447
While I am sure you are correct, you really can't fault Yamaha for wanting their new flagship sled to LOOK GOOD as well as ride good.
And I can't image there will be any appreciable difference in real world cooling ??
calltrex
189
37
alberta
You see all these yanaha updates.
Just wondering if cat is changing or updating some of the same things aswell. Its never mentiond
calltrex
189
37
alberta
Kinda got the feeling those were changes specific to the Yamaha branded sled.
yamaha has made these new changes in addition to the original changes
hard to believe cat would not update or change anything to make it better since spring. unless cat doesnt care...
Mountaintech
1,322
316
83
Bend OR
Long ago in my motocross racing days we painted the cases black to dissipate heat better, are you saying we were wrong all those years? :face-icon-small-sho
You're correct. Black does a good job. Look at all the avionic equipment in an aircraft. They're called "black boxes" for a reason........painted black to dissipate heat.
MTN_VIPER
444
NW WA St.
fourstrokesolutionsllc.com
I believe that last years Proclimb 800s were 21/49. This year they have gone to 19/50.
I was going to gear mine down to 21/49 when put the 153" powerclaw under it, until I found out thats what it already came with!
I may still go lower, but I figured that I'll try it with the 21/49 first to see how I like it.
Not sure if the Vipers are using the same gear ratio as Cat. Yamaha tends to gear they're cross-over sleds a little taller, which may have to do with diameters of the Yamaha clutches (clutching ratio).
Bill
MTN_VIPER
444
NW WA St.
21/49
what sice is the drive wheel?
And how much speed is it with this combo?
The 141" sleds are using 3" pitch 8 tooth drivers, which are the same as the Proclimbs. The shorter track sleds I believe are using 2.86" pitch drivers, but I'm not 100% sure on that.
8 tooth 3" pitch drivers are approx 7.639" or 194mm diameter.
link to additional driver specs http://fourstrokesolutionsllc.webs.com/snowmobilerelatedtech.htm
For additional gearing info here is a link to a thread that Krom posted on Arcticchat.com It mainly applies to Cats, but is usefull information.:thumb:
http://www.arcticchat.com/forum/pro...scussion/339147-procross-chain-gear-info.html
Bill
