2010-11 Arctic Cat 800 H.O. Speedwerx Fat daddy pipe and Y- pipe
6
605maverick
26
5
3
Spearfish, SD
Asking $450 Y- pipe is brand new still in the package, Pipe was run for two hours then taken back off. Ready to install and run. NO DAMAGE, perfect condition.
Speedwerx, Inc.
800cc 2010-2011 Crossfire (R) / M-Series / HCR (5,000 Ft.+) Fat Daddy Single Pipe
SKU: AC800S-8
RetaIL Price:$620.00APPLICATIONS:2010-2011 Crossfire (R) / M-Series / HCR 800 MODELSELEVATIOON:5,000 FT.+ ONLY!HP GAIN:9 HORSEPOWERWEIGHT LOSS:5 POUNDSKIT CONTENTS:SINGLE PIPE, Y-PIPE, HARDWAREOTHER INFO:REQUIRES FUEL CONTROLLER
Arcticc Cat 800 H.O. engine is out of this world. This set-up adds 9 HP over stock and is designed to run @ 8100-8300 rpm. Our pipe kit is also 5 pounds lighter than stock! Pipe comes ceramic coated with black painted y-pipe. Our pipe mounts into the stock muffler for stock sound, or we also offer a lightweight muffler for a little different sound and even more weight savings. Our pipe requires premium 91 + octane fuel and a DynoJet Power Commander PCV fuel controller.
ABOUT OUR EXHAUSTS: All of our Fat Daddy single pipes undergo countless hours of testing and development combined with hours of design and fitting. We have taken the time necessary to produce the best single pipes for your machines. Here are some of the key benefits to using our single pipes:
STRAIGHT-UP USA HORSEPOWER Every pipe is designed, DYNO tested and then field tested to produce real, accurate and reliable horsepower gains. Our pipes are not built for one run across the lake or on the trail. Our pipes are built to last and our pipes work!
CERAMIC COATING All of our single pipes come with a long lasting finish that offers a great look while also acting as a thermal barrier to keep heat inside the pipe for optimum performance.
LIGHTWEIGHT All of our single pipes are lighter than the stock system. You can expect an average weight savings of about 5 lbs.
GREAT FIT All single pipes are designed to run into the stock muffler for simple installation.
QUIET You can expect stock sound levels while using the stock muffler.
DETAILED INSTRUCTIONS Each single pipe comes complete with a full instruction/set-up sheet which includes jetting specifications if needed, clutch set-up suggestions, as well as full installation instructions.
