2005 sno pro help!!!!!
W
Dec 14, 2007
16
i have a 2005 sno pro that will not run.
it ran last fall perfectly fine when we started it up and now its got nothing.
it produces 120#s of compression on the 2nd pull and about 125#s on the
3rd, it has good spark, and even with starting fluid or gas injected straight into the cylinder through the plug hole it will not even pop off...
ANY IDEAS???????
Nov 27, 2007
213
9
18
53
no start
Thats wierd,check for intake/exhaust restiction.After storage all kind of "stuff" can or could have got in the pipe or air box.
Good luck.
M
4
18
Athena OR
X2 on the intake exhaust. Pull pipe off and try to fire it may be mouse nest plugging. If not check your reeds to make sure they are not stuck closed and not letting air in.
W
Dec 14, 2007
16
k ill check the intake/reeds/and pipe when i get a chance to get out in the garage again and let ya know if any of those are the problem.
and yes i did check spark, when you say unplug tps do you mean unplug and try it or what im kind of confused.
thanks for the help
W
Dec 14, 2007
16
well i cleaned the carbs, checked the pipe and can, checked the reeds, and cleaned the valves... it will run but it runs really boggy when you first give it gas to take off... it almost completely bogs down. even after it revs up a little it doesnt seem to be producing good power... any ideas about that?
