D
Arctic Cat:
AC roller clutch w 52-42P helix (non diamond) $100
AC roller helix (non diamond) (52-44) $15
AC roller helix (non diamond) (52-42P) $15
Polaris:
primary clutch $200
team secondary with reverse helix $150
2000 800 RMK chaincase with gears and chain $125
2003 800 RMK chaincase with gears and chain $125
2003 800 RMK carb's $125
Gen II lighweight jack shaft $100
2003 800 RMK tie rods and spindle mounts $100
edge / gen II clear tank $100
2000 800 RMK oil pump $75
2003 800 RMK oil pump $75
2000 800 RMK water pump $75
2003 800 RMK water pump $75
2000 800 RMK recoil starter $75
2003 800 RMK recoil starter $75
throttle control and kill switch $75
2003 800 RMK CDI $75
2006 rear polaris rmk suspension $75
2000 800 RMK fuel pump $50
2003 800 RMK fuel pump $50
2003 800 RMK exhaust valves (without caps, springs and billows) $50
Polaris twins Delta reeds $50
Gen II engine stabilizer $50
Edge, Gen II and Wedge front stablizer bars $50
2000 800 RMK coil $50
2003 800 RMK coil $50
brake caliper $50
Carl's 910 head (old style) $50
2003 800 RMK drive shaft $50
Lightning 62.5 gram weights for Polaris primary (actual weight 60.2 grams) $35
Gen II wedge style tunnel 136" tunnel ext with flap (from 1999 600 RMK) $25
stock Edge torsion springs $25
stock Gen II torsion springs $25
2000 800 brake rotor $25
2000 800 head cover $25
2000 800 stock rear axle $25
2003 800 stock rear axle $25
2003 edge handlebars $25
Polaris wedge ('97 RMK) headlight and headlight housing $25
Polaris wedge ('97 RMK) gauge pod $25
2000 800 RMK Carb boots $20
2003 800 RMK Carb boots $20
Polaris Gen II stock reeds with cage (2000 800 RMK) $20
Polaris Wedge stock reeds with cage (1997 700 RMK) $20
Polaris 10-58 gram weights $20
electric starter mount (5244250) $20
Polaris 10-M-W weights $15
Used Henry/Reed Pro-taper bars (cross bar removed for sled application) $15
Polaris Gen II rear bumper (136" tunnel) $15
Polaris wedge ('97 RMK) handlebars $15
Polaris handle bar hooks $15
Polaris wedge hood screens, yellow $10
4 wedge black bogey wheels $10
New Polaris RMK stickers with chick (2 total) $5
Polaris wedge ('97 RMK) handlebar cover $5
Polaris Gen II (2000 RMK) handlebar cover $5
Polaris Gen II (2000 RMK) owners manual $5
Prices OBO + shipping if applicable. Please call or email with questions. 208.412.5five4nine
Polaris:
primary clutch $200
brake caliper $50
