Well I think that we have it all figured out.
1.) Going to run the mikuni flat slide carbs (40MM)
2.) Got a water pump housing off of a newer sled and one hose to make the cooling hoses look factory
3.) Got a slp single pipe off of ebay that is made only for a 2001 700 xc (Lucky)
4.) Putting the newer stator, flywheel, and oiler so that we can run the 2001 wiring and PERC
those are the major things that we are doing but we figured that if its going to get done do it right!
If anyone is thinking of doing this and needs help I can help I have ran into enough road blocks to send you in the right direction.
