Does anyone know. Will a 154 track on a 146 Freeride (Gen 5) work as far as hitting the tunnel in the back?
I would have to assume it will be fine, just did it to a gen 4 146 Freeride. Turned out sweet.Does anyone know. Will a 154 track on a 146 Freeride (Gen 5) work as far as hitting the tunnel in the back?
What did you do for rails? I was just going to IceAge, then realized that the mount spacing may be different between the arms. In other words, the added length may be between the arms and not bewhind the rear arm?I would have to assume it will be fine, just did it to a gen 4 146 Freeride. Turned out sweet.
Went with the Ice Age rails which is a direct fit. Also changed out the chain and bottom gear to stock 154 gearing. Track from tracks USA.What did you do for rails? I was just going to IceAge, then realized that the mount spacing may be different between the arms. In other words, the added length may be between the arms and not bewhind the rear arm?
YesAwesome, thanks! 2.5 track?
I know. They just don't exist. Any brand.Too bad doo didn’t make a 146x3 track
