G
Stock pipe, Jaws can
Backshift is so much stronger. Very impressed with that aspect. I almost think it could pull more helix like a 44/38 or 42/38 or 42/40. It seems to hit 7700-7800 right off the bat and sometimes gains RPM.
I'm seeing low 40s. like 42ish MPH depending on conditions. This is around 9000 ft.
I also have a Speedwerx y-pipe to try and 70 gram weights. I thought about dropping to 70s and a softer spring to see what I get for Rs and track speed. Y-pipe should be run at 7900 RPM.
I wish Cat had weights inbetween.
Right now its running perfect at around 7700-7800 RPM. If I put the y-pipe on and want 7900-8000 RPM, I think I will over rev with 70s.
