I have an 05 King cat 900 efi. Starts and runs good cold. After it warms up the temp light flashes 6 times. Previous owner told me that he sent the ECU to cat and had tested- tests good, tried different stator, voltage regulator and different servo motor. When I bought the sled the light flashed 5 times and I found a poor connection at the voltage regulator, repaired wire and now the light flashs 6 times but only after warming up the sled and riding maybe 1/2 mile from trailer. Shut sled down, restarts good and runs good for 100 yards to maybe a mile. Checked the servo motor and it turns when the rpm gets around 7000. When the light comes on, the servo motor stops turning and the engine boggs down and you cann't get any rpm out of it.Tried running it with out the hood to cut down the electrical load- didnt help Read several posts, Will do this on a stand, has new ignition switch, runs same with switch unplugged, handle bar heaters off. Fresh fuel, plugs are damp, tried new plugs, no change Acts up sooner the harder you run it.
