O
hello,i have an 01 800 twin installed in a two seat sand car and it is running very lazy right now.I think the temp sender has gone bad,I have two senders here,one wont read and the other is showing 1140 ohms.Does anyone know what a good sender should read?My temp light is on as soon as i turn the key on so i think this is where the problem lies,i would just like to know how to test the sender.also i would like to build a bypass plug as there is no local source for an slp plug or a new temp sender and I want to fix this ASAP,do i just need to make a plug with a 200ohm resister wired into it? Does anyone know what temp the stock sender turns the ign retard on at?Is there a way to trick the stock sender to let the engine run hotter before starting to retard ignition?thanks !!
