ski doo posted in there service mateial to there dealer network last season showing some graphs on what cans did to there motors performance .
unfortunately the test was targeted at the oporation of the sleds in low elevations. there correct but to be fair the test should have shown results at elevtion. and a 7000ft reading would have shown totally different results.
riders, unerstand that a sled at sea level looses 30 hp by time you get it to 7000ft .air is thinner as you go up and the motors ability to have the same volumetric out put is dimminished .
a can that showed tight at sea level wont show tight at elevation . a loose can will preform terrable at elevation in its ability to help the main pipes performance.
the compression reading at sea level say is 160lbs
the compression at 7000 is now 130lbs
the pipe pressre reading at sea level is 3 lbs at wide open throttle
the pipe pressue at 7000ft is 2.2 lbs
we have always had the ability to dyno test at these two elevations
and the info is very valid .
ski doo should have been more concerned with who supplied them there priamary clutch components than an after market can concern.
when you want to select a can , consder these facts,
what elevation do you oporate at .
the fellas that oporate over 8000 really are running sea level 600's up there .
when considering twin pipes keep this in mind as well . can save yu some greif on a beautifull snow covered day and your buddies are rippi n it up and your not.
