thanks punk a$$!! haha ....what kind of sled do you have? That is the case with my Escape?
Chad Chad Chad.........The Edges aren't that bad.......... just grab some beers and get to it!
Does this mean you are going to ride this year?
FYI, might think about just replacing the spring while you are in there to. If ya do, don't buy the WPS one.... went that route and it broke first ride out.......
If its an escape you dont have to pull the motor just remove the pipe to make it easy then pull the recoil housing. Do not remove the center nut it is not necessary, just get the rope through the little slot in the recoil drum, cut the end of the rope and burn it a little with a lighter. Then you will want to wind it about 4 or 5 times and take the rope and put it back in the drum. At this point all you do is slowly let it recoil back until the rope end is about where the hole is in the housing and take a pick or somthing similar and guide it through the hole, works good for me. I hope this helps, once you have done it a couple of times then it will only take about 15 to 20 minutes to do the whole job. Good luck let us know how you do.
hahaha, I believe the edges are easier to change than the IQs. The RMK/Dragon IQs require removal of the engine to get the lower bolt loose. The newer ('07+ iirc) don't even have the hole for the bolt in the cover.
